Warm Boiler Room Air
Is there anyway for me to get the warm boiler room air into the house?
    Jamie Hall Posts: 27,989
    Do you really want to? It's warm… but what else is in it?
  • it’s just my house basement. Would a slow CFM fan pull the air out of the boiler room.
    EdTheHeaterMan Posts: 12,981
    Fan is not a good idea IMHO.
    Is your boiler room too hot? Do you feel you're wasting heat? Do you spend much time in the boiler room, and is it uncomfortable because of the temperature?
    There is another consideration: a boiler room can contain combustion byproducts and potentially harmful fumes. You certainly don't want to use a fan to introduce that air into your living space.
    Are your steam pipes insulated? If they aren't, that may be the source of your problem, and the proper solution is to insulate them.
    Think about it this way: You don't allow heat to escape from your heating system in the wrong places, only to build a duct system and install a fan to move that unwanted heat somewhere else.
    You insulate the steam pipes to prevent that heat loss in the first place. This keeps the heat in the distribution system until it reaches the radiators, where it is supposed to be released.
    The best way to recover wasted heat is to prevent it from being wasted in the first place.
