Homeowner Question
I have a 1 pipe gas fired steam boiler system in 1300 sq ft cape style home. I have a newly finished basement and my question is, what are my options, if any, to bring heat to my basement utilizing my steam boiler
    mattmia2 Posts: 18,393
    you could run a hot water loop off of the water in the boiler with or without a heat exchanger. you could hang radiators up high above the steam main. you could run 2 pipe radiators above the water line with a separate return.
    Mmike1632Ironman
  • Ironman
    Ironman Posts: 7,975
    If the boiler has provision for a tankless coil, you could use that for a space heating loop and thus avoid the issues that accompany using boiler water directly.
    Bob Boan
    EBEBRATT-Ed Posts: 21,315
    @Mmike1632
    What do you use for Domestic Hot Water? Can you post a few pictures of the boiler?
  • Steve214
    Steve214 Posts: 15
    Throw in some electric baseboard or possibly a ductless.
