Refractory Keeps Sliding out of Place
Hey All!
Just had my 30+ year old Bryant (made by Dunkirk) boiler inspected and cleaned for the season. The tech mentioned the refractory has slid out of place and if it continues, can cause serious issues. Is there a way to "glue" it back in place or is this worthy of a new boiler (per the tech).
Thanks,
Lew
It's a gas boiler. I can get pics, but it's back in place for the moment.
Yes, pics please. Is this a gas power burner? I'd like to see the chamber on an atmospheric gas boiler. And how did the chamber slide? That's peculiar.
Sorry for not replying sooner. Was waiting for it to move out of place.
Perhaps that technician might purchase a new car if the gas cap falls off. A new car will definitely come with a gas cap, so you won't need to worry about that problem with the old car anymore.
Actually, there is an adhesive used for combustion chamber repairs called waterglass. It is used to fasten refractory components to metal firebox parts.
You would need to remove enough parts to access the refractory material (6 on the right illustration). Apply the water glass to the refractory material, then press the refractory material against the firebox (indicated by 7 on the firebox illustration on the left).
I might then install two or three sheet metal screws from the outside of the firebox, passing through the metal so they engage the refractory material. That way, the waterglass isn't the only thing holding the refractory material in place.
Thanks for the help! Going to see if this is something I can do. Otherwise, will get more quotes.
- 136 Chimneys & Flues
- 16.2K Strictly Steam
- 52 Industry Classes
