Refractory Keeps Sliding out of Place
Sweet_Lew
Sweet_Lew Posts: 136
edited November 2 in Radiant Heating
Hey All!
Just had my 30+ year old Bryant (made by Dunkirk) boiler inspected and cleaned for the season. The tech mentioned the refractory has slid out of place and if it continues, can cause serious issues. Is there a way to "glue" it back in place or is this worthy of a new boiler (per the tech).
Thanks,
Lew
    EBEBRATT-Ed Posts: 21,413
    We need more information on the model of boiler Gas or oil fired?
    And some pictures will help. The refractory could be a minor issue that can be repaired or it could be a real problem. Some techs see a few minor cracks and tell you you need a new boiler.
    Sweet_Lew
  • Sweet_Lew
    It's a gas boiler. I can get pics, but it's back in place for the moment.
    HVACNUT Posts: 7,845
    Yes, pics please. Is this a gas power burner? I'd like to see the chamber on an atmospheric gas boiler. And how did the chamber slide? That's peculiar.
  • Sweet_Lew
    Sorry for not replying sooner. Was waiting for it to move out of place.
    mattmia2 Posts: 18,491
    seems like there's lots of ways to glue or wedge that back in place
    Sweet_Lew
    EdTheHeaterMan Posts: 13,046
    edited November 21
    Perhaps that technician might purchase a new car if the gas cap falls off. A new car will definitely come with a gas cap, so you won't need to worry about that problem with the old car anymore.
    Actually, there is an adhesive used for combustion chamber repairs called waterglass. It is used to fasten refractory components to metal firebox parts.
    You would need to remove enough parts to access the refractory material (6 on the right illustration). Apply the water glass to the refractory material, then press the refractory material against the firebox (indicated by 7 on the firebox illustration on the left).
    I might then install two or three sheet metal screws from the outside of the firebox, passing through the metal so they engage the refractory material. That way, the waterglass isn't the only thing holding the refractory material in place.
    Sweet_Lew
  • Sweet_Lew
    Thanks for the help! Going to see if this is something I can do. Otherwise, will get more quotes.
