Crazy venting
SteamNow
While I was on a service call this week I found the following venting. I couldn't take a picture because after I shut off the gas the owner started freaking out so I left. But this was crazy. I called the mechanical inspector and state fire marshall about it.
Owner
Steamnowrockford.com
1
Wonder if the owner put it in like that?
sounds like you did the right thing. I wouldn't expect the HO to call you back though, but he should call you and thank you. You may have saved his family.
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
