Steam Radiator brand identification
Hello fellow steam brothers, need help identifying this brand Rad as I have a few. Fow reference, 5 tube rad measures 8" in width and 25" in height, 15 sections at ~ 38" in length. Note tap port/point just above the end plug. Looks like 1920s to 1930s styling similar to Arcos. Top end plug has a triangular shaped logo, might be an A plus other figures IDK. Pics are attached.
many thanks for all the help.
HNY and best regards
    Steamhead Posts: 18,976
    Hard to make out what's on the plug, the pics are a bit out of focus.
    The radiator itself, according to your measurements, should be a standard type of large-tube radiator similar to the American Corto, National Aero and others. Ratings were standardized by then so any large-tube chart should apply.
    Semi-retired
  • MarkZeh
    MarkZeh Posts: 54
    Steamhead, hello, hope all is well with you and HNY. You have previously helped me with a few other issues in the past, and I Thank You very much. Rad dimensions are similar to Arco Corto. 8 x 26 for 5 tube falls in line with Arco Corto but mine are 25" high. Guess worse case is that I tool down the listed EDR by 5%, should be close enough for my Btu calcs. I will see if I can remove some paint off the plug for a better pic. Looked clear enough but have never seem that type of logo before as well as a tap point just above the plug. Most likely you have.
    Again, thank you for all your help
    best
  • RTW
    RTW Posts: 285
    Looks a lot like the Greek Delta symbol, just sayin
    Regards,
    RTW
  • MarkZeh
    MarkZeh Posts: 54
    Appears after long search from downloads in the HH Wall - Museum, Rad brand was identified as H.B. Smiths 144"s. sizing and design match as well as the position of the tap just above the top radiator plug.
  • MarkZeh
    MarkZeh Posts: 54
    Meanwhile, have obtained an old Victorian era Rad from a bldg in the Bronx NY. Not positive, but believe she is an old Arco - Rococo style. She stands 43" tall, approx 7-1/4 wide with 7 sections, 2 columns only. Can someone plz verify manf of this Rad. Looking to have her cleaned like new and installed somewhere in my home.
    Many thanks
    mattmia2 Posts: 18,238
    it will say roccoco near the bottom tapping if it is one. but it looks like it is.
  • Dave in QCA
    Dave in QCA Posts: 1,811
    I'm 95% sure that the radiator you show is made by Kewanee and it is their copycat version American Radiator's rococo model. The pattern is nearly identical, but not exactly. I think I have a Kewanee catalog that I could dig out if anyone doubts me.
    Dave in Quad Cities, America
    http://grandviewdavenport.com
  • Definitely not a Rococo.
  • Dave in QCA
    Here is my kewanee "rococo"
    is that a steam only radiator where the top sections aren't connected?
  • Dave in QCA
    My example is steam only.
