National Radiator Cast Iron Push Nipples
I’m looking for 2 National Radiator push nipples that measure 1 3/4 on the outside.
  • kcopp
    kcopp Posts: 4,727
    What it wrong w/ the current ones? You may very well be able to clean those up w/ steel wool and add a skin of sillicone to the male and female sides the use the draw rods to pull them back together. I have can great luck w/ that.
    Depending on you location you will need to hit a established supplyhouse to see if they have old stock.
    EBEBRATT-Ed Posts: 21,228
    Something in my brain clicked "Oswald Supply"
    kcopp
