Is this a special insulation?
Kungur
There is a form type insulation wrap on the line going from my condenser to the house. It looks like it needs to be replaced.
What would you use?
no pictures
I ASSUME it’s Armor Flex. It’s not UV rated so the sun broke it down. You can order it on line and replace it. Get the “Split” type. Paint it with a UV paint
Thanks!
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
