Gravity hot water radiator connection
Bubbleheadtoo
Member Posts: 1
What is this? This is on all the second floor radiators. It was originally a coal fired gravity hot water system.
Some type of double flow fitting. The tee probably has a baffle or a partition in it
or a lance like the danfoss fitting
@Bubbleheadtoo , this is a piece of heating history. I can't make out the name on that special tee, can we get a better pic?
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
