Looking for a book on residential vapor systems
Mail4tommo
Mail4tommo Posts: 90
edited August 27 in Radiant Heating
Just is the title States, looking for something that has some knowledge on vapor systems for residential homes. One pipe and two pipe.
From what I've been learning rather quickly.. most homes depending on the side of town they are tend to be vapor homes. I mainly used to one pipe it two pipe with traps
Thanks guys
    i don't know if most residential 2 pipe systems are vapor or if people with them just end up here, but we see far more posts about vapor residential systems than conventional trapped 2 pipe systems.
    have you read
    it covers many other steam system types too but it is probably the modern book with the most coverage of vapor systems. if you really understand how steam behaves vapor systems are not much on top of that. there can be mixing and matching too. it is common to set up certain problem types of emitters as 2 pipe within 1 pipe systems such as baseboard fin tube or fancoils.
    it is all just thinking about what happens to the steam, the air, and the condensate.
    Mad Dog_2Mail4tommo
    Steamhead Posts: 19,007
    This one too- it has a LOT of Vapor info:
    https://www.heatinghelp.com/store/detail/the-lost-art-of-steam-heating-companion/
    Semi-retired
    mattmia2Mad Dog_2Mail4tommo
    the companion is excerpts of the source documents used for the diagrams of the various steam system in TLAOSH
    Mail4tommo
    I agree about the LAOSH as mentioned above.
    The other place to look is in used bookstores that you can search online. Look for American Society of Heating, Air conditioning and Refrigeration.
    If you want to find one with vapor systems, you going to have to dig deep.
    Steam has been pretty much dead for residential since 1950.
    Vapor's heyday was the 1920s
    So you will be looking for old books.
    Mad Dog_2Mail4tommo
    Lots more than that. Where, for example, would you find the Imico system in the original?
    Semi-retired
    Mad Dog_2Mail4tommo
  • Mad Dog_2
    Mad Dog_2 Posts: 8,755
    Between "The Lost Art...", "Pocketful of Steam..." and "We got Steam Heat.." you're going to find everything you need to know book-wise, theory and drawings. The rest you'll learn In The Ring. Mad Dog
    Mail4tommo
    Here are a couple more Vapor systems that are covered in Lost Art Companion but not in the OG Lost Art:
    Hutchison (out of Washington, DC)
    Ideal (out of Cleveland, OH)
    Imico was out of Chicago, and used "Dewey" components. The name was an acronym of the Illinois Malleable Iron Co. I wonder if that company morphed into the Illinois Engineering Co?
    Semi-retired
    Mail4tommoMad Dog_2
  • Mail4tommo
    Thank you gentleman, I have most of those books listed above. @Mad Dog_2 you're absolutely right the ring is what it is 🤣👍
    Mad Dog_2
