Thermal Energy Network in NYC Subway?
2»
  • That is the software that we use for the forum, @leonz. Sometimes a post will get blocked if it's too long or if you've posted a bunch within a short period of time (spam blocker). I'm not sure what happened here, but glad you're able to post again.
    Forum Moderator
  • You do need to activate links by hitting the return key after you type them. The "Are you a human?" page is part of Science Direct's site and not related to us. Thanks!
    Forum Moderator
  • I've had the pleasure of getting involved with a roughly 20 year old building in the city that was built with a top of the line open loop geothermal system. The Engineers behind it thought they had solved all the buildings cooling and heating needs and the building wouldn't even need the typical cooling towers. Unfortunately issues arose pretty quickly and it turns out the magical top of the line system has been nothing but issues for years. It's been half redesigned by someone who left no documentation, had a cooling tower added to supplement, and it's mainly held together with hopes and prayers at this point.
    Anyway, could it be done? with enough time and money almost anything can be done. The optimist in me says what the they propose would be a nice improvement to a space many of use routinely spend a lot of time in. The pessimist in me says it'll be nothing but problems. The realist in me says that it's probably just not worth the cost compared to what benefit there might be.
    Mad Dog_2
  • DCContrarian
    DCContrarian Posts: 1,588
    The key takeaway is that it's not like this hasn't been thought of and even tried before.
    That's what's so galling about the line, "Electing smart people pays off." They're acting like no one else has ever thought of this before.
    And I generally like Mamdani.
    Mad Dog_2GGross
    hot_rod Posts: 28,701
    I have met and talked with some of the hydronics and thermal folks at NYSERDA.
    I know they would give an honest assessment based on thermodynamics, basic heat exchange and heat transfer.
    I hope they get opinions from , and trust experts like that over political pressure.
  • leonz
    leonz Posts: 1,994
    Not going to happen Bob, they will not give the consumer any tax credits or discounts for coal fired central heating either when it is done in a rural area.
  • Intplm.
    Intplm. Posts: 3,160
    Hmmm. Testing- yes, testing the idea, says the above article. Testing the idea seems like a good start rather than blundering into it. I'm sure we can agree we have all seen too much of that.
  • leonz
    leonz Posts: 1,994
    Thank you for correcting my error EBERATT-Ed. Would an air handler fed with the cold water pumped out a well in the granite be the better option? Would a forced draft radiator in the air handler also sweat?
    A Mesabi radiator could be placed in an air handler and be easier to maintain as it has individual vertical fin coils that can be replaced if they leak or a sealing O-ring leaks. I would imagine the air filters in the air handler would have to be replaced more often.
  • leonz
    leonz Posts: 1,994
    edited August 15
    You should see the size of the heat exchanger fin tube coils at the Lake Source Cooling Plant in Ithaca, New York Bob. The pipeline coming from the University is gravity fed downhill and pushed uphill by the water flowing down hill to the lake source cooling plant.
    The lake water is pulled through one pipe passed through the heat exchangers finned tube piping and pumped back into Cayuga Lake with a parallel pipe.
    A wide deep trench was blasted out of the limestone bed rock from the foundation of the building to the point where the bed rock ends at deeper water for both pipes and the company Angelica Boring out of Angelica, New York used a tunnel boring machine to bore the twin rock tunnels to the building basement where the twin pipes enter the building.
    PC7060
    EdTheHeaterMan Posts: 12,945
    There are some very smart people that are saying they can take all the extra summer heat out of three subway stations in New York and remove it (making those stations cooler) and storing it somewhere so that the following winter they can put that stored heat into the buildings around the subway stations so they don't need to run the heaters as much.
    WOW. That is Awesome
    Where are they gonna put all those Thermos™ bottles filled with the hot summer air?
    PC7060Intplm.
    A very large hydronic unit heater turns the hot air to hot water. I imagine plenty of places to use thermal in NYC, even in NYC. Pipe it to the Mikvahs, they use mega amounts of hot water daily :)
    Ot an A2W DHW heat pump, for hgigher efficiencies.
