Uponor thermal actuator
How do I reattacheban actuator that has come off its platform
    mattmia2 Posts: 18,246
    need more information. pictures? usually they screw on with a metal ring.
    109A_5 Posts: 4,627
    Assuming it is not broken. One version;
    GGross
  • rick in Alaska
    rick in Alaska Posts: 1,530
    If you are talking about the black (silver) square shaped ones, if they come off it is most likely broken and will need to be replaced by the style 109-a showed. That black ( or silver) style is no longer available.If it is like the one he showed, then use his info to reset it.
    Rick
    also if the pin is stuck it might push itself off
