Main vent.
Niss3zx
Niss3zx Posts: 13
I am aware this set up is incorrect. Any other options to configure? I plan to replace this gorton # 2 with a Barnes & Jones big mouth to obtain more height. As you can see from the pic I had to make a hole in basement ceiling to obtain some room. Have some more room going upwards but am limited. This is a multi family building with parallel long runs approx 30ft. I plan to change both sides with the Big mouth and replace the short runs with The gorton #2. Weil mclain Eg-75 series boiler i believe its a 282,000 btu
