YOU WANT TO HEAR A GOOD ONE?
So, about a week and a half ago, @JohnNY posted the question , "Taco should have a video showing how the 570 zone valve works." I had often thought that would be a good thing to have, but I couldn't find one, so I decided to see if some AI program could take the Taco brochure, instruction sheets, and all the information available online and simply "make the video."
...That didn't work either.
Then I looked at some free animation software on the web and typed up a sequence of operation that I put into the AI program HeyGen, which helped me create my first AI avatar video. Now I had a soundtrack and a still screenshot of the Taco valve diagram, but I still had no way to make the thing move.
Then I thought about the old flip-book cartoons I used to make in my Textbooks in 7th grade, where you made a stick figure walk across the bottom of the pages.
This is what I came up with:
EDIT: This is the finished version. The original is below it.
I
Now, a couple of you gave it an AWESOME icon, and I thank you guys for that. I wonder wha @Joe Mattiello and @SteveSan from Taco would think of it .
It took over a week to modify each part of the animation one frame at a time and to learn how the video software worked. I still couldn't figure out how to "render" the video after I was able to play it within the program. So I went old-school again and simply shot a video with my iPhone of the animation running on my laptop within the free video editor software.
I was able to use the same frame over and over again once I got each frame in the proper sequence, especially the part where the heat motor switch opens and closes repeatedly during the call for heat.
I hope you like the video, and as I get better at this, the quality will get better too.
7 -
seems liek it would be hard to reproduce that, to get the ether in the cylinder through the open valves at just the right concentration to burn.
I would give you an "A" for that. The only thing missing I think would be to label the wiring terminals on the valve.
"YOU WANT TO HEAR A GOOD ONE?" It's right here. Awesome.
Very well-done Ed! Shared with the team and all were impressed.
@SteveSan I have been working on this program and have discovered how to actually render it from the OpenToonz software. This is my finished copy and you folks at Taco are free to use it in training programs you provide and post on your web site
I would use it in conjunction with this piece of literature you have a few copies of laying around. https://s3.amazonaws.com/s3.supplyhouse.com/product_files/570-2-brochure.pdf
2
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
