2 Radiators branched off 2" main steam line
Heating Help steam guys, quick question for best piping layout for new re-routing of steam rads from reno job. Previously had a single rad, ~6480 Btus piped with 1-1/4" from 2" main then reduced to 1" steam valve. New slightly larger Rad, ~7680 Btu, is to be installed about 4 ft to the right from the original with an additional new rad installed to the left, ~3840 Btus. I am planning of 'T-ing' off from the 2" main line port with either 1-1/4" or 1-1/2" pipe then pipe to rads. Just want to make sure that I will have sufficient steam to both radiators. Any insight or suggestion?
Many thanks for all comments.
Mark Z
The problem isn't sufficient steam — you'll likely have that with the 2 inch main runout — but it is the pitch of the pipes from the T to the radiator. Both of them must pitch back to the T. They will need about a half inch of pitch for the four foot runs… and getting both of them to pitch back to the T just might be a bit tricky?
Jamie, thanks. Hear ya clearly. Think I should be OK since the 4' run will consist of 2' to the right then another 2' forward. An L. So I prob will get some OK pitch from the T but more/better pitch going towards the rad itself. Any thought on 1-1/4" or 1-1/2" piping? Original from main line T was 1-1/4"
Thanks
This is where swing 90's or 45's come into play to get the slope needed. And also to correct the riser to get it plumb to meet the rad valves.
Jughne, correct, that was my exact thought, going to right I can use a 2 x 90deg street elbows to obtain the pitch needed. Plus main is piped in parallel flow pitching down to the left so I already have the correct pitch from get go, just more pitch would be better. To the left I will have a long enough run to obtain a decent pitch with a little upward flex of the 7' pipe. If not back to using a couple of elbows.
EBEBRATT-Ed, thank you, nightmare cutting into 2" main as piping is in a crawl space with limited access and currently have some flooring already up for that access. Agree, less than ideal but will have to make it work.
To all, thank you for your great words of wisdom.
Mark
You need to look up if that 1-1/4 can handle the additional condensate being produced. Your run outs are counterflow to the radiators. You need to make sure that the condensate will slide by the steam without picking it up. if it doesn't slide by you will have a hard time sleeping in that room. @EBEBRATT-Ed is absolutely right. i was going to suggest the same thing.
Pedmec, thank you. Went through these mental gyrations several times last night. Know what the right thing to do is rather than plumb it wrong and have to disassemble the world beneath the floor. Will be cutting the 2" main line, new branch off T - 5 feet to the left of current and Union fitting. Not the end of the world but TG I'm only 5'8" and am still reasonably flexible. Kee you all posted
Steamhead, as you helped me so well in the past with another steam problem, promise you folks some pics.
Thank you
Steamhead/Pedmec/Jughne/Ebebratt/Jamie; looking for a how to plumbing suggestion.
Current Steam piping diagram attached. Need to connect union to Tee fitting from where main was cut out for new plumbing. Face to face measurement from Union to Tee depicted in dwg is ~40 3/4". Am able to move/sway end pipe with elbow #1, 1/4-1/2" to left and right. Need to install a 2" pipe section into one end of union fitting with the other into the initial Tee #2. Any recommendations on how you guys would tackle this? Understand take away measurements for a 2" line for a Union and Tee are 1-1/8" and 1-1/2" respectively. At those additional lengths added onto the ~40-3/4" pipe length, might have a huge pipe wrestling match on my hands. Maybe Add union fitting onto pipe end first then try to thread into Tee fitting? Think I can move pipe w/ Tee down some to form some more
wiggle room. Are the above take aways too long? Any suggestions to save me a ruined day would be greatly appreciated.
Thank you
Don't know about the measurements but if you can't move the pipe enough to get it together you can use 2 unions.
2 sets of flanges may be better but the unions will work. I did this with a 3" condensate return where we had to pullup the floor to do the fix and it worked out fine.
40.75 face to face would give you and end to end of 42". I usually allow 5/8" each end but it can depend on the dies etc.
Hope this helps
ed, thank you. Clear. Ok, home depot is cutting n doing threads. Guy there told me the machine cut threads to abt 1-1/8” n cant be adjusted. So thinking of doing like 40-1/4” plus thread lengths making pipe 42-1/2”, think this will work. Thoughts before hd guy cuts?
What I would do in your situation is figure out the end to end dimension of the pipe you need.
Lets say you buy a coupling and three nipples a 2" 2 1/2" and 3".
Screw the 2 1/2" nipple into the coupling and screw the coupling on a pipe then cut it your end to end distance. If it comes out too long you take the 2 1/2" nipple out and use the 2". If it come out too short wit the 2 1/2 put in the 3".
You can always return the nipples you don't need.
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 123 Geothermal
- 79 Pipe Deterioration
- 396 Solar
