Indirect- Going away,shut it off?
Cyclist77
Cyclist77 Member Posts: 269
I have an Weil-McClain CGa3 and indirect dhw. Planning to go away for 2 months. I'm guessing I should shut the system down?
Thoughts?
    mattmia2 Member Posts: 17,562
    in the summer, yes. in the winter the answer is more complicated.
    EdTheHeaterMan Member Posts: 12,534
    IN THE SUMMER YES, IN THE WINTER THE ANSWER IS MORE COMPLICATED.
    in case you didn't hear Matt
  • Cyclist77
    I suppose could turn the indirect dhw off via the SR in the winter. But we don't tend to go away for more than a few days at a time .I like the snow!
    i remember those days! Skiing, ice skating, hot chocolate by the open fireplace.
    Don't worry, you'll get over it some day!
    EBEBRATT-Ed Member Posts: 20,545
    @EdTheHeaterMan
    Your right about "getting over it" For me it was Ice skating I had a pond within a short walking distance from my house. I would sit in school looking out the window wondering what shape the ice was in. Couldn't wait to get home to grab my skates as soon as school was out. I would miss dinner and get home around 8:00.
    Caught a lot of flak because I should have been doing homework…….and my report card showed it.
    Then my father and my sister who was a teacher would make my life miserable LOL
  • kcopp
    kcopp Member Posts: 4,707
    I would be careful about shutting it off… What temp does it run at? It prob would run one time every 2-3 days. not a lot of gas.
    Leaving water at room temp for long periods of time would be a possibility of legionella bacteria growth. When you return run that at 150f for a few hors or drain the tank out.
    @Markeatherton2 has a story of a vacation home where the results were not great.
  • Intplm.
    Intplm. Member Posts: 3,088
    I'm not familiar with the cga3. If it is just a water heater and you will only be away for two months, there really is no need to do anything. If it's a combi boiler and it is winter time/chance of a freeze-up, winterize it with non-toxic glycol or empty it dry.
