Monoflo fittings unused
luna12
luna12 Member Posts: 10
I have a Monoflo system from the 50s and I will be replacing the boiler with a Weil-McLain CGa-6 cast iron boiler. The system has two circuits, but only one circulator. While examining the piping, I came across two sections that I have questions about. Both of the sections have two unused fittings. One of the fittings is a Monoflo T and the other is a regular T. Myfirst assumption was that they were remnants from an old radiator that was removed. But perhaps they were strategically placed there to affect the flow rate.
Can anyone tell by looking what the likely purpose of these fittings was?
Also in the first pic, I additionally circled a shut off valve that is for circuit #2. Circuit #1 has no shut off valve. I don't understand why they added a shut off to just one circuit, but as you can see from the pic, the two circuits bifurcate in that area. I was thinking perhaps the shutoff was used while filling the system to make it easier to fill circuit # 1. Then they opened the shutoff to fill circuit number 2. Is that a plausible theory?
  • ScottSecor
    ScottSecor Member Posts: 1,043
    Each monoflow tee has the equivalent of twelve feet of pipe. The shorter the pipe (less restrictions) the easier it is for the heated water to flow to the system. I suspect someone thought they may need these tees for another heating element (perhaps a basement heater?). Ideally, you would remove all of the unused monoflow tees, as they only hurt system performance.
    As far as the valve goes, I think the original installer was concerned that one side of the monoflow system would flow better than the other. You could better balance the system with the (again restrictive) valve. It appears the "balance" valve is wide open. Do not attempt to adjust it, as the square head will likely break off.
    luna12PeteAHomerJSmith
  • PeteA
    PeteA Member Posts: 328
    This site is awesome!! There is always so much to learn here. You guys/gals are all truly generous with your time and knowledge, it makes it enjoyable to come on here and learn something new all the time.
    Alan (California Radiant) ForbesIntplm.
  • markdelzell
    markdelzell Member Posts: 30
    The 12' pressure drop is vastly overcome by the ups26-99 3 speed pump we install on the new boiler.
    Also I don't see shut off valve you're talking about?
  • markdelzell
    oh I see it now, plug valve.
    mattmia2 Member Posts: 17,753
    what is going on here, is one bot replying to another bot?
    Intplm.
  • markdelzell
    ha
