Taco 007e
is the taco 007e variable speed? Does is constantly adjust when boiler is running? The directions say something about adjusting after 7 days.
As far as I am aware, it is not variable speed. It has a function that is built in, that if the pump is on for more than 24 or 48 hours (cant remember) it will go into like a half speed mode.
Here are the instructions
Tom
Montpelier Vt0 -
Yes it is. But it is not something you can change. It is designed to maintain a specific head. It does that by staying on the multiple pump curves built into the programming of the circulator. if you had a multi zone system with zone valves and as valves open and close the flow changes, the head will change. initially the oo7e will run up the curve or down the curve it's on but that will take it off the fixed head position. the pump will adjust to another curve to maintain the fixed head.
2 -
@Tom_133 does not believe the Taco 007e is a variable speed and included the instruction sheet that clearly states the opposite.
I'm going to agree with @pedmec who believes it is a variable speed.
But there is a question that I have: Why do you need to know this? Which usually translates to: What problem are you experiencing? That problem may have nothing to do with the circulator, So have at it! Whats the reason for asking?
it’s not what you would consider a tradition variable speed pump, you can’t manually adjust it like a 0015, but it’s a “smart Circ”. So in circumstances where you need the pump to adjust itself, multiple zone valves, it will do it automatically, but I wouldnt replace a 0015 for a 007(not that you’re trying too) both variable speed but not the same kind
That's why this forum is good. As long as no one develops a "thin skin" and those providing the "correction" are not arrogant, there is plenty of "peer review" that exists for good "second opinions." Ultimately the information becomes…more reliable. All of the above is a good example…making for a very good forum.
4
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
