Reverse return
fxhvac1
fxhvac1 Member Posts: 1
I’m working on a reverse return hydronic piping system and added a sketch for clarity. After the last radiator, should both the supply and return mains be capped, or just one of them?
. Thank you
    Jamie Hall Member Posts: 27,383
    Don't really need a cap —those lines can just stop at the radiator!
    Except… your diagram isn't a reverse return at all. It's a simple parallel. To make it a reverse return, the return line should start at radiator 1, then pick up the others in order, and THEN come back to the close spaced Ts with no connections.
    hot_rod Member Posts: 27,481
    the "dead end" method would require more piping.
    Screenshot 2026-04-06 at 8.41.33 AM.png Screenshot 2026-04-06 at 8.41.47 AM.png Screenshot 2026-04-06 at 8.42.23 AM.png
