IBC boiler and hard water
wrxz24
wrxz24 Member Posts: 325
Looking to replace my Triangle Tube boiler that is 14 years old. I went with a TT with SS heat exchanger due to my hard water. The guy that I know and trust, installs IBC. IBC have different models. Any recommendations for which model t go with? I’m particularly curious about the one with aluminum hx but with copper waterways.
Also a side note, does IBC have settings for 2 separate heating curves like my Triangle Tube to control baseboard and infloor radiant zones? TIA
    hot_rod Member Posts: 27,451
    is this a combi boiler? The boiler should only need to be filled once .
    unless you have leaks in the system it should not take more water
    You can buy a one time filter cartridge to fill the boiler which takes 90% of the minerals out, it is best to start with good water, regardless of copper stainless, cast iron, aluminum material
    Most boiler brands have a variety of models . The upper models have the most control options. Search the model options at their website
    The controls that offer multi temperature output can only provide one temperature at a time unless you use an additional mixing device
    wrxz24
  • wrxz24
    No I will have an existing indirect. As far as the curves, yes one at a time with TT as well. I do have mix valves for when the high temp curve is being satisfied. I’m looking specifically at the SFB series.
    https://www.ibcboiler.com/consumer/products/sfb-superflow/
  • kcopp
    kcopp Member Posts: 4,677
    I have installed a bunch of SFB and SFC.
    They are a decent unit. Simple design but effective.
    I have a SFC in my own home.
  • wrxz24
