Seeking advice, new to boilers, boiler broke over winter
2»
    mattmia2 Member Posts: 16,762
    edited March 28
    it is doable but probably not worth what you'd save in gas on the pilots.
    you'd either need to find an ignition control with 2 flame rod inputs or wire 2 ignition controls in series.
    or use a self resetting baso switch in series with an ignition control
    it would be easy if you could still get mercury flame sensors, youd just wire them in series.
