The Fatal Venting Error in Room 225, This weeks video
RayWohlfarth
RayWohlfarth Member Posts: 1,987
edited March 27 in THE MAIN WALL
This video discusses three cases of sidewall venting done wrong, resulting in four fatalities. Sidewall venting of flue flue gases is a cost effective solution if done right.
Ray Wohlfarth
Boiler Lessons
GGross
    Steamhead Member Posts: 18,508
    I'm surprised this doesn't happen more often, based on some things I see in the field……….
    Consulting
    clammy
  • RayWohlfarth
    @Steamhead I know its kinda crazy what installer do
    Ray Wohlfarth
    Boiler Lessons
  • clammy
    clammy Member Posts: 3,256
    Its kinda amazing that this continues to happen . It makes me think who are the idiots who do these types of job without any clear thoughts of the end results just plain stupid or just kids listening to a blind eyed owner or sales guy . i Kinda believe that also that most gas pool heater should not installed within a building unless hard wired in a co monitor which dis engages the power to the unit. The saddest and stupidest is hotels where the pool pump and filters are housed in the same indoor mech room w all the pool chem w usually zero outside combustion air and in a few cases no indoor transfer grills to allow fresh building air into the room . The other note is most pool guys do not service pool heaters ain t there jobs so they usually go un serviced and usually that's part of the issue as the draft collector rots and drops on the heat exchanger and bang you got a issue and it s been a while since servicing a gas pool heater but i would gather two spill switches might help being i don't ever remember seeing them but i'm old and forgetful now .
    Thanks Ray
    peace and good luck clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
    PC7060
