Radiator plug
alanm
alanm Member Posts: 149
i have a plug/screw …that i need to take out…..does not move..tried spraying lubricant…still no luck…any suggestions…..
    ethicalpaul Member Posts: 8,742
    If the plug's slot is still intact you haven't tried enough 😅
    Keep working it, perhaps try an impact screwdriver, and when the slot is mangled and useless, then you get the drill out.
  • TheClevelandSteamer
    TheClevelandSteamer Member Posts: 19
    edited March 19
    • 1. Heat it up with MAPP gas torch.
    • 2. Hit is with an impact driver. Readily available at Harbor Freight, Amazon, Home Depot, etc for under $20. It's basically a screwdriver that you smack it with a hammer and it shocks the screw, usually enough to break it loose. I've never had one not come out using this tool.
    Repeat 1 & 2 until it comes out.
    If those fail, drill it out with an extractor.
    PC7060
  • alanm
    thanks….so "hitting" the impact driver will not damage the radiator?
    mattmia2 Member Posts: 16,673
    edited March 19
    you need to use discretion. if you go all out on it with a short handle sledge you will drive the bit and plug right through the radiator but if you use some moderate taps with a short handle sledge you might get it out.
    it helps if you hold a bit of pressure on it so the tool is up against the cam and it isn't bouncing on the spring when you strike it.
    @EBEBRATT-Ed you are trying this type of impact driver on your plugs, not the electric or pneumatic kind, right?
  • alanm
    havent done anything yet…i jsut saw the comment about using the impact driver/hand
  • Long Beach Ed
    Long Beach Ed Member Posts: 1,833
    I assume you wire brushed all the paint off the screw and surrounding metal? Sprayed it with a penetrating oil for several days, or a week or two if you have time, whacking the screw a few times each day? The oil won't get into the threads if there is paint in there.
    After this, try a few shots with the impact driver. Get an American-made one if you can.
    If that doesn't work, try heating with a torch, more oil and then the impact driver.
    You should be able to get it out if it's an old, USA-made plug.
    EBEBRATT-Ed Member Posts: 20,145
    @mattmia2
    Waiting for the weather to warm up. I tried the electric impact and got 1 out. The others I cleaned the paint off and sprayed with Kroil oil. I have the hand impact but haven't tried it yet. Too cold to shut the heat off and I have other work to do on the boiler…change the expansion tank and turn the air scoop around which has been backwards for 25 years. So I will wait I only wan't to drain it once if possible. If they won't come out I will drill and tap.
    PC7060
  • bburd
    bburd Member Posts: 1,302
    Umm… maybe I'm missing something here, but those lower vent openings are intended for steam systems, and if you have an expansion tank and an air scoop you have a hot water system. Unless you have a hybrid of the two.
    Cast-iron radiators on hot water systems should have manual air vents at the top of the end of the radiator. Air will rise above the water.
    Bburd
  • 4GenPlumber
    4GenPlumber Member Posts: 151
  • alanm
    this is steam heat
    bburd
