Can you use a tankless water heater to lets say Heat a small pool? only for a day!
Mail4tommo
Mail4tommo Member Posts: 51
Could a tankless water heater recirc the water in the pool? Its only used for a few hours once a month. So lets say it heated and filled the pool, could it keep that pool hot 86 degrees for less than 24 hours? If so this would be my best option for a project. Thanks in advance
    Alan (California Radiant) Forbes Member Posts: 4,702
    edited March 8
    Most pool heaters are tankless, so it depends what size you choose.
  • Mail4tommo
    @Alan (California Radiant) Forbes Thanks, I'm not looking for a pool heater, I'm looking for an answer so I can make a decision based on the answer
    edited March 8
    My question is: What size tankless do you want to use. They have different sizes.
    I’ve seen Mikvah’s heated with tankless units, but I don’t remember BTU’s or gallons capacity.
  • kcopp
    kcopp Member Posts: 4,665
    Should combine this into 1 post…
  • Mail4tommo
    @Alan (California Radiant) Forbes I just need to know if they are capable of recirculating what it puts in. As if it heats up something let's say a tub for example can it keep that tub hot with a recirc pump
    Jamie Hall Member Posts: 27,276
    Depends entirely on the heat loss of the pool — but in general, I'd say yes. But it seems to me there is another very similar thread just now about a baptistry?
  • jesmed1
    jesmed1 Member Posts: 1,455
    The pool heat loss should be less than 20,000 BTU/hr at 86 degree water temp and 68 degree indoor temp.
    Mail4tommo
  • Larry Weingarten
    Larry Weingarten Member Posts: 4,073
    Hi, I'd expect a very big pressure drop through a tankless heater, forcing you to use a bigger pump. Using a pool heater (which is designed for low pressure drop) with a pump sized for good flow through the existing piping seems the simplest approach. 🙂 Do you know what the gas supply piping is to the heater that leaked?
    Yours, Larry
