Ultra 230-4 outdoor sensor
heaterbeater
Member Posts: 2
Is the outdoor temp sensor the same resistance profile as two indoor ones? The book is unclear . Thanks.
I’m pretty sure they are. Take an indoor one. And connect it to the outdoor sensor connection and see what it reads.
There would be a chart for the outdoor sensor if it was a different resistance profile.
Tech support at Weil should know for sure.
Thanks .I hope you're right.
Instal the sensor and check the readings .. Instal the outdoor sensor NW corner not over a window or heat source ..
- 120 Geothermal
