Cut in a copper dwv fitting with little room
I have a good one for taking inside measurements but I'm confused as to how you can use one for level and plumb. You can make it straight vs something else but not level or plumb unless the other thing is one or the other.
i think that is the point, that you can't.
I agree, I carry one regularly. Offsets, bending, reading prints, scratching my back, pointing out others mistakes...the uses are endless. 50/50 solder was so much better, poison, but better.
yes on the 50 50
No on the B tank, just the little Mapp hand helds (we ran two for disassembly)
no finger licking- my finger tips know the drill
stick rule! Sorry I missed that generation. I recall the old dudes when I was getting into the trades in the early 80s. I though “man that’s kinda odd”
you must be old school too🇺🇸💯
Alan we gave it a flush and it was all dry- good enough!
@mattmia2 hmmmm I can’t think of any
- 120 Geothermal
