Identifying part in hydronic system
ohanasam
here is some info on how it operates
Living the hydronic dream2 -
Thank you ScottSecor & hot_rod. Much appreciated.
No problem. We used to use them often with single speed pumps (on off) with many zones.
This is on a 5 zone heating system and an indirect. Three Taco 0010 pumps (DHW, Boiler & Heating). Just always wondered what the device was and now I know.
What size boiler, or heat load do you have?
That circ is a flat curve, ideal for zoned systems. In its sweet spot it would like to be flowing 12-20 gpm, mid curve
cool info in this thread, I’ve never came across one of those valves
Its is a 140k BTU boiler (heating 5000 sqft across two floors) at 7800ft altitude in Colorado
- 87.8K THE MAIN WALL
- 132 Chimneys & Flues
- 79 Pipe Deterioration
- 396 Solar
