Dryer in a laundry closet with little clearance
My washer and dryer are in a laundry closet in the kitchen. I am replacing both and have a challenge with fitting the new dryer. To put it simple, the duct comes into the closet vertically through the floor. A 4" adjustable elbow was used to go from the vertical outlet of the duct to the horizontal connection on the dryer. That takes up 4+ inches of the floor space. Between the wall and the back of the dryer.
The existing dryer is about 24 inches deep and the new one is 28 inches deep. I have only about 4 inches from the front of the dryer to the bifold doors. I may be able to trim the dryer end of the elbow to gain some space. In looking on the web, I found a "periscope" dryer vent on the Supply House web site.
I wonder if using it would give me more room instead of the existing elbow. It doesn't seem to help much if at all.
Another option is to use flex duct instead of the elbows to make the transition from the dryer to the horizontal duct in the basement directly below the dryer to the back of the house
I don't want to cut into the wall to run the elbows/duct, if it isn't absolutely required.
Suggestions, other than get the "boss" to buy a smaller dryer…
Hi, Does the new dryer vent only out the back? Some are designed to be able to vent out the sides. That could give you some options. 😇
Yours, Larry
you could build a platform to put the dryer on, elbow it back in to the periscope below the platform then connect the periscope in to the back of the dryer on top of the platfoprm.
you could shop for dryers by dimensions, i think bosch makes a particularly compact one.
you could possible extend the doors out one way or another.
LOL. I did pull it up the cellar stairs while she was gone to NH to visit her grand kids. I started on it the second she cleared the front door.
I had to put a 5/8 threaded rod with an eye bolt on it through the closet wall so I could use a come-a-long.
When she got home the wall was already patched. I did show her some pics. The only downside was I couldn't get it out of the condo by myself so she had to look at the water heater sitting in the kitchen for two days until my brother showed up😎🤥
2 -
I have a simpler solution. The washer is on the left of the dryer. Between the washer and the left side wall of the closet is about 8 inches of space where I have a laundry bag that catches dirty clothes being dropped from the illegal laundry chute. I can move the washer to the left enough to align the dryer with the existing duct.
But I will have to reconfigure how the clothes drop into the bag. It's easy, just put the big round blue wash tub that wee store on top of the washer on top of the bag next to the wall and let 'em fall. The good thing about this is the "Boss" already has considered it, but not yet mentioned it to me. She also prefers that I not mess around with the dryer vent.
So, at least as a first attempt, keep the "boss" happy, do nothing with the dryer, eliminating a headache and she will live with how the dirty laundry lands in the tub. No muss, no fuss, no $$ or time expended.
Time will tell.
Although it sounds like you got it figured, I’ll post for other reader. Building a dry box is simple and allows for the dryer to be just a couple inches off wall. Be sure to plan for access to remove dryer at later date
From inside the box you can go up/down/left or right.1 -
that type of vent is not a great idea, although it is slightly harder to melt than plastic that aluminum will still evaporate if there is a fire in the dryer
Like the plastic duct used for bathroom fans, the film is "flimsy" and easily cut.
OEM Datasheet: Heavy-duty Semi-Rigid Aluminum Duct is UL2158A listed and marked for safe dryer venting. It is ideal when UL all aluminum duct is required by code in some gas and electric dryer applications. This duct is totally noncombustible and has a maximum operating temperature of 435 degree F.
Good luck on your install!
My concern with the arrangement was primarily not wanting to reduce the space available for the laundry chute bag. I mentioned the possibility of losing some space to my wife and she said she had already considered it! Duh, so much for wanting to keep the boss happy by not encroaching on her domain.
We decided to give it a try. The dryer was installed at the existing location. The washer was located as close to it as possible. So far, so good. Time will tell.
If that didn't work at initial installation by the supplier, I would have potentially eliminated some "service" responsibility for the seller…which I did not want to do. So, I overthunked it.
Bottom line I prepared for the worst and was able to get the "best".
1
- 87.8K THE MAIN WALL
- 133 Chimneys & Flues
- 79 Pipe Deterioration
