Texaco FCS boiler
Was going through the house file last night and I found an invoice for when this particular boiler was installed in the '70s, I'm just curious about the history of it etc.
Is it still there? If so, how about a pic?
Consulting0 -
Frank,
It's long gone. It was replaced by the Burnham V7 that I currently have in 1998.
BTU/h and installed Sq Ft Radiation is the same? Back then they didn't know.
Let's see the sale price.
it looks like it looks like there was a receipt attached, but is long gone
In the Hydronic Rating Handbook, it says Texaco marketed these through their Paragon division. The FC/FCS appears to be a rebranded Dunkirk 13 series. That one had a rating of 1.95 GPH with whatever burner they used at the time, and 595 square feet EDR.
Consulting2 -
That's about half of what I have now, boiler currently installed has a rating of 379 square feet of EDR and a firing rate of 1.05 GPH
I think I remember working on them around here (NJ) in the 1980's. "Texaco" brand oil burners were very poplar around here. I believe they were actually Beckett AF oil burners with a Texaco label.
As usual, Steamhead is correct. A Blue Circle with a green jacket and red burner
🎵 You can trust your home 🎵 to the man that wears the star, 🎵 the big bright Texaco star🎵
- 116 Geothermal
- 169 Indoor-Air Quality
