Rinnai R85e, no power to controller, no hot water
Robert_Sorenson
Member Posts: 1
I thought I would share my experience hoping it helps others. I have a 2005 Rinnai R85e instant water heater that went dead between showers. No power to the controller, removing the controller wires from the board didn't help. Confirmed 120VAC to unit, checked continuity of both fuses, confirmed power going to transformer 120VAC and 100VAC on secondary side of the transformer (had to use small wires since my tester was too big but don't let them touch! Or get ready to buy new fuses, how do you think I learned). Once power to the control board is confirmed, unplug everything from the control board (leave the small power supply screwed to the front of the control board plugged in) except for the plug coming from the secondary side of the transformer. If you have power to the board but no power (24 VDC) at the terminals going to the wall mounted controller it's a bad board. I bought a new one from Rinnai through a local dealer for $200 overnight shipped and have hot water again. Make sure to check the 2 DIP switch settings and set the new board to the same settings. Hope this helps someone. Rinnai tech support was outstanding and walked me through the last steps when I hit a diagnosis wall but wasn't ready to sink the $200 yet.
1
Hi @Robert_Sorenson , Welcome to HH, and thanks for sharing your experience. It sounds like aside from that pesky fuse, things went well. Might it be useful to have the heater on a surge suppressor? I'm just wondering why the board died...
Yours, Larry2 -
I am having the same problem with unit no power is going to it. Checked my panel big and breaker is not blown. Power unit on wall is blank and tankless heater does not seem to show any power as well. I need help trying to figure it out0
That is an electrical problem -- particularly if both the boiler and the tankless heater are out. Are they on the same circuit (they shouldn't be, but we'll overlook that)? The breaker is not tripped -- but are there any emergency switches which might have gotten turned off (there should be at least one -- but there may be two)?Br. Jamie, osb
It is 2025 and my R85e plus has the same problem as Robert_Sorenson in 2020. Unfortunately, the PCB (IGE-199R-10N-E printed on it or replacement U245-500-F-HX01) are discontinued. at the moment, I can not find any PCB to do the repair. Very likely, I have to buy a new unit.
Any insight/advice?
I think the controller on my r85 is bad, no matter what I do nothing comes on on the controller. I was hoping somebody could tell me if there's a way to bypass the controller to get some hot water while I wait for the new part to arrive.
