Old Watts LWCO sill available
yes we got rid of the full time pilot line, plugged it off at the old Petcock. We snugged the pilot assembly into the new valve. I was going to tie the vent line in, but then realized that thread was much smaller. I talked to RobertShaw, he told me it wasn’t necessary.
The stat is a T87. If the system continues to act up, I’ll scrutinize that a little bit. The safety circuit is pretty basic, vapor stat, lower , and then thermostat or the other way around, it doesn’t really matter. It’s just a circle.I stuck my Seitron down its throat and the numbers were amazingly good. Super low CO.
is that extra aluminum tubing a pilot lighter or is that just abandoned vent lines?
- 50 Industry Classes
