Water heater expansion tank mounting
What do people think of water heater supply valves meant to hold expansion tanks, like this one?
My water heater currently doesn't have an expansion tank. I don't have any check/backflow prevention from the city supply right now, so there's no huge concern there, but I'd like to be able to safely shut off the main water valve for extended periods, so I want to add an expansion tank. My water heater is under a fireplace hearth, so if I support an added expansion tank from above, I'd either have to locate the exp tank farther from the water heater than I'd like (long dead leg) or drill into cement (I'd rather not).
Three above fitting/valve supports the tank from below, but not by the body of the tank. Would you consider using that in my situation?
If you are closing off the water feed to the whole house, you should also shut off the burner or element to the water heater. Then you will still not need an expansion tank. I don't see any reason to have the water to the entire home/building shut off and continue to heat the water in the water heater. Can you?
But to answer your question, that tank holder will carry the weight of the tank under normal use since it should never actually be full of water. You want to be sure that the pipe connecting to the water is properly supported as soon as you get past the masonry ceiling.
Yes, the water heater should be turned off, but I'm not always the last one to leave the house for a weekend or an extended trip. I can give instructions to turn one lever, but probably not how to turn the water heater off all the way.
I think most all water heaters have a vacation setting. That allows them pilot to stay on, but the burner should not fire..
Understood. Teenagers can be so unreliable …as can spouses. Good idea for the expansion tank! It makes the job stupid proof.
Hi, If the water is going to be shut off, maybe also open a tap (best physically higher than the top of the tank, like a shower) and let it drip to relieve any possible pressure? 🤔
Yours, Larry
