Taco ECM circulators
gpjazz
gpjazz Member Posts: 71
I was simply trying to find a comparison chart or something for available Taco ECM circulators that shows the specs of each model, but not having any luck with Google.
On the Taco site, I can look at the models and then click to view the specs. But I wanted something simple for a quick view, like a list showing the different models and specs altogether as a comparison.
Does anyone have any insight on this ?
    pecmsg Member Posts: 7,043
    have you contacted TECO support?
  • gpjazz
    Negative.. Was just hoping I could easily find something online for comparisons
  • yellowdog
    yellowdog Member Posts: 293
    There is nothing easier than calling the manufacturer.
  • GGross
    GGross Member Posts: 1,877
    A list of specs use AI to create it like @Robert_25 did for you. I would urge you however to look at the more important specs that are not so easy to put in a side by side comparison and that is the pump curve. What I have done when I needed a physical copy to quickly look at is print the various pump curves for common pumps I deal with. If you know your systems requirements (which you must know to properly spec out a pump..) using the various manufacturers pump selection tools is typically easier than using the old field books they hand out, though I do think both are nice to have. I have been specifying pumps for over a decade and never found a need for a list of pumps and specs, it's not relevant imo. Pump curve trumps it all, your available voltage on site tells you which voltage pump to go with, and if you can't find one that meets your requirements with the correct volute length then you will need to re-pipe
    Robert_25
  • SteveSan
    SteveSan Member Posts: 298
    @gpjazz I reach out to one of the Product Managers and she put together the attach list of our residential ECM circ pumps. Please let me know if this is what you were looking for.
    If you have any questions, please give Taco Technical Services a call during normal business hours Mon-Fri 8am-5pm EST 401-942-8000 and just ask for Technical Services
    GGross
  • gpjazz
    Yes.. This is exactly what I was looking for !!
    Thank you !
    SteveSan
  • SteveSan
    You're welcome. Glad I was able to help.
    Larry Weingarten
