Condensate tube freezing
Hi Everyone.
In the extreme cold, the tube that runs from the condensate pump on my propane boiler is freezing (outside) and clogging with ice. Any suggestions to prevent this from happening?
    pecmsg Posts: 7,634
    Yes
    Move in where it's not below freezing.
    You may have to discharge it into a bucket and manually drain it until the freeze ends.
    EdTheHeaterMan Posts: 12,950
    The laundry tub is a good place to place the condensate pump tube. Or the washing machine drain pipe if you don't use a laundry tub.
    Hi Everyone.
    If you don't use the heater anymore then the pump will not fill with condensate.
    But that would be an extreme that you may not want to consider. Try @pecmsg idea first
  • JUGHNE
    JUGHNE Posts: 11,653
    I have had this problem for a couple of sites.
    I took the 3/8" discharge tubing up overhead and then down the wall on the inside of the room.
    Then take the pipe (increased to 3/4") out the wall at a 45 degree angle.
    The height makes the tube drain out quickly and prevents freezing.
    Still working at -10 or lower.
