Wow have you seen the new gas meters?
Stopped by a clients building and saw the new gas meters as well as one of the old. Cant believe how small they are
Boiler Lessons
the last time the replaced my water meter they replaced it with something similar. it is basically a piece of plastic pipe with a display on it.
Yes. Tiny, comparitively. I'VE seen Old Style Gas Meters in the Phone Company Building in Lower Manhattan that were 5 feet tall…crazy Mad Dog
i assume those are not using a pair of bellows?
I've seen them online. I've been curious how they work and how their accuracy is.
Those might have been sized to run backup generators. Which building was it?
Consulting0 -
Do you have a link to that post? Thanks.
Yeah, I've seen those in the wild. I've got an Old Guy's distrust of them new-fangled things. We'll see how well they work in 50 years.
I think they are all meant to be swapped and refurbished at much shorter intervals than that. I like when the bearings on the bellows rods get noisy and you can hear them slowly creaking at the rate of gas usage like a block away.
That was the old AT&T HQ building. The original equipment in there would have dated to the 1920s and used a lot of power. It could run on either line voltage or "talk battery" which was 48VDC. Fascinating stuff, especially considering the limited technology of the time- just like our Dead Men.
Consulting2
- 15.8K Strictly Steam
