Vent or plug
Hello fellas ,I found this at the ends of both mains. Is this a vent of some sort or a plug? Thank you in advance! I love this site and read it everyday!
    ethicalpaul Posts: 9,076
    Can you blow through it? If not, it's a plug…or a plugged vent
  • 4GenPlumber
    4GenPlumber Posts: 176
    Take it apart. Are there any markings on it? It kinda looks like an automatic hot water bleeder, but its missing the holes.
  • TMS1980
    TMS1980 Posts: 11
    it doesn’t come apart but it looks like it would. Can’t blow thru it. Just wondered if it was some special weird device. Thanks for the quick responses.
  • 4GenPlumber
    Check if it has left handed threads
  • 4GenPlumber
    Pull off the c-ring first.
  • TMS1980
    TMS1980 Posts: 11
    No left handed threads. I’m good without it. It was on a tee that was bushed down to 1/4” I removed and replaced both vents already but wanted to double check
  • TMS1980
    TMS1980 Posts: 11
    C-ring doesn’t budge. I cleaned the inside of it out and it’s flat at the end. It’s empty. I don’t know. I’m going to say it’s not important.
    Steamhead Posts: 19,007
    Any name on it?
    Semi-retired
  • Intplm.
    Intplm. Posts: 3,162
    edited January 25
    looks like a capped male by flare adapter. Possibly used as both a plug and when the cap is cracked open, used as a vent.?
  • TMS1980
    TMS1980 Posts: 11
    no name. Same size on both mains. Just a basic one pipe system
    looks like a cellulose disc type bleeder or a small relief valve.
