Heat Pump Water Heater
mitt
Member Posts: 1
Do you know of anyone that makes a heat pump Water Heater that recycles condensation back into itself?
Like to return to the water supply? That's not advisable! Also it's not enough to even worry about. Or is there something else you're thinking of?
You might be capturing a pint or two a day - there is not a lot you'll get from that.
I can't imagine why anyone would want that water for anything.
I put it in my steam boiler 😅
well the water heater only makes condensate in the summer
See my sight glass boiler videos: https://bit.ly/3sZW1el0
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
