Radiator Noise
Getting a high pitch ting at the radiator furthest from my boiler. Control valve and trap on radiator are new:
https://youtube.com/shorts/K1_y4TwXjBo?si=BQX1oxYUgYdzE1VO
Sounds like water hammer maybe but wanted to see group thoughts. The piping to this radiator has many bends, the radiator has never heated past the third section.
Thoughts? Thank you!
    Jamie Hall Member Posts: 27,323
    Sounds much more like expansion noise.
    BobCmarkmarlatt
  • BobC
    BobC Member Posts: 5,565
    See if the pipes coming from that radiator are up hard against anything and try slipping a piece of plastic milk jug between that wood and the pipe. Also try shimming both ends of that rad up about 1/2" to see if that helps.
    Bob
    3PSI gauge
    markmarlatt
