Wrapping Steam Pipes
I recently moved into an 1860s home in Vermont, equipped with a boiler and steam radiators. Some of the pipes have been wrapped using asbestos materials, some are unwrapped, and some have deteriorating wrapping. Photos attached, here are my questions:
• Would you cover asbestos wrapping in plastic and then cover that with fiberglass insulation? • Any specific insulation recommendations?
• Why do you suppose the large pipes attached to the boiler are not wrapped at all?
Leave that old stuff alone … We use fiberglass pipe insulation today . The steam mains need pipe insulation to work as designed .. It is a good investment ..
There are two ways to deal with Asbestos. Remove or encapsulate. Both should be completed by professionals. Both will cost you dearly. If, by chance, you find an inexpensive way to remove all that asbestos and clean all the fibers that can float thru the air, then you need to replace all that insulation with 1” thick fiberglass pipe insulation on all the larger (pipes 1-1/2" and larger) and 1/2" pipe insulation of the smaller pipes from 1" down the 1/2". And if you do it up right, there are nice vinyl covers for all the fittings.
I have used this website in the past for steam pipe insulation:
1
- 121 Chimneys & Flues
- 15.8K Strictly Steam
