Why we use copper on relief valve discharges
I think the current plumbing codes allow relief lines to be any material suitable to the discharge temperature? So I see the plastic tubes being passed now, looks like the same material as the dip tubes.
Old codes required metallic discharge tube as I recall.
I dont use pvc for discharge, but better than this! Scary. Mad Dog
Hi, A benefit of copper is you don't get galvanic corrosion where copper meets the brass valve. A detail is the line is supposed to be run down to no more than six inches off the floor, so people are less likely to get burned. No doubt @EBEBRATT-Ed could comment on the wiring in the first photo too. 🤨
Yours, Larry
2 -
in michigan it is worded such that water heaters need to be metallic but boilers just need to be rated for the working temp of the system.(at least as of the 2015 code we've been using for a decade, the new code may be different, not sure if we've actually are using it yet, it was adopted then some lawsuit paused it)
Octagon box with no cover and 4 runs of romex in it. Two runs of romex in one clamp only allowed if the connector is listed for it. Looks like one of those ground clips on the box edge to ground the box. I hate them but its code so I will let it go this time. But don't do it in my town ever again. And no romex staples seen. The romex has to be secured within 12 " of a box. I will have to look up the box fill for 4 #14s and 4 Grounds in a 4" octagon but I think its ok.
MA. is probably stricter than most states.
how exactly does one find the listing for a romex clamp? they come loose out of a bin…
@mattmia2 , everything has a listing. Even zip tys have to be listed for electrical
842 Product Information Cable Connectors for NM • SE • SEU Cable
Basic Information
Part Number
842
Description
NM cable connector zinc die-cast. 2 screw clamp type. Handles combinations of NM cable from #14 to #10. Up to 2 NM cables at one time. 3/4 Knockout. Also handles one 8/2, two 4/2 service cable.
UPC-A
018997008428
Unit Packaging
50pcs
Standard Packaging
500pcs
Country of Origin
Listing
- 15.8K Strictly Steam
