burner motor specs
Robert_H
Robert_H Member Posts: 294
I recently replaced two Carling burner motors. Both capacitors are dead. and the motor resistance values follow:
Motor
orange
orange
white
white
Capacitor
blue
white
blue
white
Carlin Spec (ohm)
12-16
6-8
20-27
<1
Motor 1
14
8.4
20.1
Motor 2
13.5
6.6
20.3
motor one, orange to white is slightly out of spec. does anyone see a reason why I should not reuse these motors with new capacitors?
    EdTheHeaterMan Member Posts: 12,035
    Replacing capacitors is always less expensive than replacing the entire motor. I see on problem with that .
    Robert_Hrick in Alaska
