Heat Pump good for -32F
Has anyone had any experience with "Flooid Power Systems" low temperature heat pump systems? They are in South Hadley, Mass.
Years ago I found some information on developments with lower temperature heat pumps, but never something come of it. I think the work was going on in Vermont.
    Jamie Hall Member Posts: 27,005
    Their web available information is a little low on specifics…
    hot_rod Member Posts: 27,072
    Dakin and AAON Extreme Series, ultra low ambient, -20F, These may be dual compressor type heat pumps. probably more for commercial sized equipment.
    EBEBRATT-Ed Member Posts: 19,887
    edited January 2
    South Hadley is about 6 miles from me and I don't know anything about them not that I would anyhow.
    At —32 how much time in defrost??
  • SteamingatMohawk
    SteamingatMohawk Member Posts: 1,090
  • ChrisJ
    ChrisJ Member Posts: 17,148
    Depends on the dew point, no?
    If the dew is -50 probably not much.
    Hot_water_fan
