Boiler PRV's This weeks video
RayWohlfarth
RayWohlfarth Member Posts: 1,977
edited January 2 in Strictly Steam
This video goes into how the pressure reducing valve works on a hydronic system. It also discusses the pros and cons of keeping the valve open or closed on the incoming pipe. Hope you enjoy it.
Ray Wohlfarth
Boiler Lessons
  • Mad Dog_2
    Mad Dog_2 Member Posts: 8,538
    Excellent! Mad Dog
    Intplm.
  • sctronic
    sctronic Member Posts: 4
    I was taught to leave the water off. That way you'll know if you have a leak. Continuously adding water is never a good thing.
    Steve
  • OuterCapeOilguy
    OuterCapeOilguy Member Posts: 55
    There's another cause for increasing pressure, which I'm sure Mr. Wohlfarth, with his long experience, has encountered. That would be a pinhole or leak in a tankless coil or the hydronic heating coil in an indirect water heater. I've experienced both at one time or another. This allows domestic water system pressure-which can be as high as 60 psi-to pressurize the closed hydronic system to the point where the relief valve opens.
    Fastduramax
