Triangle tube after recall- Supply Sensor
wrxz24
wrxz24 Member Posts: 305
Had the recall done end of October for ignition and yesterday had a lockout due to Supply Sensor stuck closed. I hit reset and it started and ran all night. Is the sensor serviceable or needs replaced? Wiring issue? TIA
I’ve had the boiler since 2012, it’s been pretty reliable part wise but now that the company ceased operations, not sure how long parts will be available. Should I start buying replacement parts now or save up for a new boiler?
  • Grallert
    Grallert Member Posts: 1,062
    These are good questions I don't have an opinion on. So I'm bumping this as I sure there is someone who does.
  • JMWHVAC
    JMWHVAC Member Posts: 104
    The supply sensor is one part that I have had to replace on several TT units. With that fault code, it may not appear for a while but sooner or later it will appear again. The other part I have been needing to replace is the water pressure sensor. Even tho it still reads correctly, I have seen quite a few dripping with the water coming thru the sensor. So, I'd advise those two items for on hand parts. The unfortunate thing with TT has been that the parts seem unreasonably expensive.
  • JMWHVAC
    I should have added that both parts are quite easy to replace.
