Triangle tube after recall- Supply Sensor
Had the recall done end of October for ignition and yesterday had a lockout due to Supply Sensor stuck closed. I hit reset and it started and ran all night. Is the sensor serviceable or needs replaced? Wiring issue? TIA
I’ve had the boiler since 2012, it’s been pretty reliable part wise but now that the company ceased operations, not sure how long parts will be available. Should I start buying replacement parts now or save up for a new boiler?
