Filling of in basement oil tank - Noise Reduction Help
Boiler Talk
Boiler Talk Member Posts: 147
edited December 2025 in Oil Heating
There is a 275 gallon tank in a basement, but when it was being filled it made me think there was some sort of calamity about to happen. It was loud like an alarm to get the heck out, but after running toward the matter I learned what I never knew. Filling it made an enormous amount of noise in the home. What are possible solutions to lower the noise?
  • HydronicMike
    HydronicMike Member Posts: 411
    You really shouldn’t hear much while it’s filling. And it only happens while it’s filling. This isn’t a real problem
    Now if it’s over pressurizing the tank, that’s a potential problem.
    mattmia2 Member Posts: 17,905
    are you talking about the whistle that tells the driver when the tank is full?
    Or are you just hearing the flow of oil through the fill pipe?
    If you have ever been in a basement when it is being filled it is a little loud. Gurgling oil and the whistle.
    There is nothing to do it only take a few min to fill.
    kcopp
  • Big Ed_4
    Big Ed_4 Member Posts: 3,561
    There is a vent alarm in the tank , it will whistle as the tank is filling venting out the air . The whistle extends into the tank from the vent pipe on the top of the tank.. When the whistle stops , it lets the oil driver know the tank is full. .. It is needed …
  • Boiler Talk
    The whistle works, and the tank seems OK, but its just the noise at fillup. Rumble of flowing oil and of course the whistle. It reminded me of a broken water pipe that was flooding, or the noise in the house when a garden hose running at full - copper pipes. 'What in tar-nation was happening?" There are no bushings to dampen any sounds.
    edited January 1
    how often are you filling this tank that hearing it for a few minutes is a problem?
    kcoppSuperTech
  • Big Ed_4
    edited January 1
    You could sound proof the wall but not the tank .. The tank needs ventilation to the outside …
    Basement Appartment ?
  • leonz
    leonz Member Posts: 1,909
    if it is bothering you that much you could insulate the ceiling over the tank or move it outdoors.
  • Boiler Talk
    I will have to live with it in the basement. Perhaps a double lined tank would have been quieter, but its the typical tank and was to replace an in ground tank.
    Insulate the floor? Not sure that would matter much, unless the entire floor was considered.
    Grin and bare it. That's the solution I guess. Thanks, folks. Happy New Year.
    Add another tank and you won't have to fill as often.
    But when you see the cost you will decide 1 tank is ok.
    EdTheHeaterMan Member Posts: 12,661
    @Boiler Talk replied "Insulate the floor? Not sure that would matter much, unless the entire floor was considered."
    I believe this is in response to @leonz's comment "if it is bothering you that much you could insulate the ceiling over the tank"
    If I might interject that a basement ceiling joist and a first floor floor joist is one in the same. That said, you can often put a wall all around the fuel oil tank and place insulation in the ceiling joist above the tank and on the walls that you enclose the tank with. That small building project often reduces noise from the fuel tank. You will want the wall to be somewhat permanent but also removable for service and inspection of the tank. A creative handyman or DIY can come up with a solution for this problem. The other solution is to schedule fuel deliveries when you are at work, then you will be too far away to hear the whistle and the liquid flowing.
    I have an old stereo console with some pretty large speakers. If you don't want to use my first two suggestions, then you can play the radio or phonograph at a high volume on the day you expect a fuel delivery. That way  you won't hear the tank filling process anymore. I use this same concept in my car when there is a squeak that is very annoying, just turn up the radio… no more squeak… and that saves me on high repair costs.
