FA32 relay question
tonynap
tonynap Member Posts: 30
edited December 2025 in THE MAIN WALL
I finally had to replace this relay - GE 3ARR4 FA32 - which happily buzzed its butt off for at least 20 years.
The one I removed did not have this teardrop shaped tab on it and I'm curious as to its purpose.
TIA
When you see hoofprints think Zebras not Horses
    EBEBRATT-Ed Member Posts: 20,155
    Don't know where you found that everywhere I looked it said obsolete etc
    I would suspect that tab with the hole could be rotated to use for a mounting screw. just guessing. Is that a potential relay?
    HomerJSmith
    109A_5 Member Posts: 3,963
    Looks like it keeps the relay from spinning.
    HVACNUT Member Posts: 7,426
    Better. Quieter. Cheaper? Pretty light.
  • tonynap
    Hi Ed, I purchased it from carbonbrush dot com. It was very hard to locate, but it is an exact replacement and installed.
    HVACNUT I'm sure you're correct. I chose this one because it was on the boiler and was able to get the exact replacement.
    You guys are great thanks again
