FA32 relay question
tonynap
Member Posts: 30
I finally had to replace this relay - GE 3ARR4 FA32 - which happily buzzed its butt off for at least 20 years.
The one I removed did not have this teardrop shaped tab on it and I'm curious as to its purpose.
TIA
When you see hoofprints think Zebras not Horses
Looks like it keeps the relay from spinning.
One Pipe System0 -
Better. Quieter. Cheaper? Pretty light.
Hi Ed, I purchased it from carbonbrush dot com. It was very hard to locate, but it is an exact replacement and installed.
HVACNUT I'm sure you're correct. I chose this one because it was on the boiler and was able to get the exact replacement.
You guys are great thanks again
