Article about ConEd's Manhattan steam network in "Works In Progress."
mattmich
mattmich Posts: 232
edited December 2025 in THE MAIN WALL
I saw this article linked by David Brooks of the New York Times.
There appears to be no paywall, and aside from some quibbles, I found it interesting and well researched.
https://worksinprogress.co/issue/steam-networks/
cheers -matt
ArthurPeabody
  • I just read it and logged in to recommend it.
    Steamhead Posts: 19,007
    They totally forgot about Latent Heat, which gives steam its remarkable heat-moving capacity.
    Semi-retired
    reggibburdMad Dog_2
  • amr14534
    amr14534 Posts: 4
    Rochester NY (about 50 miles from Lockport where Holly was born) has a downtown fire protection loop throughout the center of the city called "The Holly Loop". It maintains 135-140 PSI working pressure. Still in use over 125 years now. I saw an original high pressure pump on display.
    Mad Dog_2
    Baltimore once had a High Pressure firefighting system- not sure they still do.
    Semi-retired
    Mad Dog_2
  • Mad Dog_2
    Mad Dog_2 Posts: 8,755
    Fantastic article and history. These men made City-Dwellers' lives exponentially better. Thank you for putting us on to it. Mad Dog
  • jumper
    jumper Posts: 2,625
    I thought that ConEd used steam from back pressure turbines? Sometimes I try to design thermocompression steam heat. Condensate may make satisfactory make up water for cooling towers. I suspect those giant oil refineries use a form of district steam heat?
    CLamb
