Flue Draft Diverter needed?
I have had a new Utica UH1606HSID boiler installed for combo single pipe steam + hot water loop heating. It is in the basement, and the flue goes into the chimney. Yes, there are separate liners for fireplace and boiler/water heater.
my old Bernham boiler had a draft diverter.
TThis new utica doesnt need one?
  • bburd
    bburd Member Posts: 1,303
    The draft diverter is built into the boiler, between the top of the access door and the flue pipe. Take a look up inside there.
    Bburd
    mattmia2HomerJSmith
  • JaymeHart
    JaymeHart Member Posts: 74
    excellent. thank you.
    bburd
